Cbr 900rr petcock
Old Oct 3, 2010 | 01:33 PM
+turbo's Avatar
Default Cbr 900rr petcock
Hello everyone I'm new to the forum and I just purchased a 94 cbr 900rr and the fuel petcock is leaking fuel. I did a search and all I can find is that they are expensive and that the other alternative it to fix it with a repair kit. The only problem is that they tried to fix it with jb weld and now I would be able to fix it. My question is will other petcocks from other 900rr fit ex. 99 cbr 900rr
Old Oct 4, 2010 | 10:20 PM
cbr900racer77's Avatar
I would bet that the newer model petcock would screw right on. Only problem is the newer ones are vacuum operated and you'd need to run a vac line.
Old Oct 4, 2010 | 11:28 PM
LJ Harp's Avatar
Official CBRF Decal Man
Does a 96 run off of vacume
Old Oct 5, 2010 | 12:48 AM
+turbo's Avatar
Yeah I saw that they need vacuum. I think that Im just going to fix it. I will post some pics and steps to fix it if it works.
Old Oct 5, 2010 | 04:44 AM
Shadow's Avatar
www.mrcycles.com
Maybe they can help you
Old Oct 5, 2010 | 06:36 AM
Stien514's Avatar
I fixed a petcock on my 89' 600 by drilling the rivets out, replacing the ring. I had to drill and tap screw holes where the rivets once were but it worked as a permanent fix and fairly easy.
I wasn't trying to be a cheap a$$, it was just a matter of pride as a smart a$$ at the dealership said they could not be repaired, so I had to put the little nerd in his place.
Old Oct 5, 2010 | 09:30 AM
I'm pretty sure it does. Look at your petcock. If it has a small hose running to it along with larger fuel line then it runs off vacuum.
Old Oct 5, 2010 | 09:33 AM
If you can't find anything else that will work, Pingel makes petcocks for them. They are pricey but worth it in my opinion. I gave 80 bucks for mine few years ago. I'm not sure if they have a single outlet so you may want to check. I bought the dual outlet because I was running nitrous at the time. Might work as a last resort.
Old Oct 6, 2010 | 02:56 AM
+turbo's Avatar
yeah I took it apart and I tapped some screws but I cant find an O-ring that fits.
I got a set of assorted o-rings but there either to small or too big
Old Oct 12, 2010 | 12:53 AM
LJ Harp's Avatar
I would advise to go to a tool repair shop like a whitecap construction supply, apex, or some sort of place that fixes nail guns and what not they have odd sized o-rings if you pm me the diameter of it i can get you a part number... i use to work for a tool shop and still have access to the books :-)
