boost or not to boost
Old 04-13-2008, 08:53 PM
rons93rr's Avatar
Default RE: boost or not to boost
oohh!! i get ya,
i did read somewhere on the forum that someone said that a cbr 1100xx motor was fit to an earlier 900 frame. they said that the motor was 2 inches wider so the frame had to be split and custom spacers welded in to accomodate the size difference. just food for thought.
by the way in your pictures is the red,white & blue bike yours? it looks very clean, i have the same bike. not too many clean ones out there. well i for one can't wait to see what you end up with. oh yea, jay lenno has a jet powered bike, powered by a helicopter engine totally whicked. if you happen to have any of those engines laying around or maybe you could do that for your 60th b-day. ha,ha,
Old 04-13-2008, 09:05 PM
Ghusar's Avatar
Yes that bike is clean! al OG and are you interested in the plastics on it?
I wonder how much a blackbird motor is....
Old 04-16-2008, 05:08 PM
javier's Avatar
i put 05 1000rr motor on mine
Old 04-16-2008, 05:11 PM
Ghusar's Avatar
ORIGINAL: javier
OK I am biting how hard was it?
Old 04-16-2008, 11:31 PM
If you do decide to turbo it, just setup it up like you would any boosted carb. vehicle, either replace your carbs with blow through setup ones or modify yours to accomidate or setup a draw through system which if you are going to make a new manifold anyway then that would probably be the easy way to go
Old 04-16-2008, 11:37 PM
Ghusar's Avatar
ORIGINAL: 89ls1
explain the draw thru system to me...
Old 04-17-2008, 06:42 PM
javier's Avatar
u dont wana know but its the only 900rr with that swap i think https://cbrforum.com/m_231442/tm.htm
Old 04-17-2008, 08:52 PM
Ghusar's Avatar
I decided that I am gonna boost it.. I will post pics when we start
Old 04-17-2008, 08:56 PM
javier's Avatar
true good luck
Old 04-18-2008, 01:57 AM
good luck man. we will wait pisc.
Quick Reply: boost or not to boost
