95 eliminator on a 93 will it work?
just that i am wondering if a 95 900rr fender eliminator kit will fit on a 93 because the 95 looks curved but the 93's tail is flat?
anyone has done this or what modding will it take?
thanks
JonBrown
thanks
JonBrown
the tail on a 93 t095 900rr is the same if you look at the pics i sent you one has the part number on and i think the phone number for air teck as well or you can go to the web site and look it up the fender eliminator i have goes mounts up under the tail like a uner tail light kit would
yea i checked the number and everything and it isnt a fender eliminator it is more like a replace ment fender isnt it? i am new so you have to give me some slack so yea what does it take out and replace?
you dont take out anything you simply slide it up under the tail and bolt your plate to it it hides the ugly black battery box area under your tail
JonBrown
you cut off the big black thing that holds the blinkers and plate (fender)and then you slide the fender eliminator i have into place and drill the holes for your plate and mount it to mount the fender eliminator in place you use two sided tape or drill holes but i would use tape it looks cleaner
fasteddie
Oct 25, 2005 09:23 PM
