93 Front end to 98 ?
RE: 93 Front end to 98 ?
well, either 98 or 95 front fits, its a matter of what's lesser overall in cost. All the front's are slightly different from the 93 so you'll need the front mask, headlights, wire harness if you intend on having the appropriate gauge cluster, upper mirror/fairing mount, lower fairing mount (the one that holds the gauges and headlight support.... 2 mids.... 2 lowers... front fender with caps & mounting hardware.... & tank (You have to have two holes drilled and add the height for the tank... I've read forums detailing on how to do it... I hear JB welding stuff but if you want a clean look, you'll need to get aluminum welded, drilled, and tapping threads the 96 and on tanks are thinner and easier on the legs... I'm uncertain but it may be possible to bend the mirror mounts(that bolts to the side of the frame on the 93' to fit right in and not have to mess with all the tapping and drilling).... the 95's had the front mirror mount just like the 93 94 so if you want a clean fatory look, go for the 95-97 front.
Nero
F4i - Wanted
07-31-2011 03:22 PM
bammerman
F3 For Sale / Trade
35
08-04-2010 09:40 AM
TMAX
CBR1000F Wanted / Swap
11-18-2009 12:41 PM
Hayden06F4i
05-03-2008 09:35 PM
