93 carburetor Vs 99 Carburetor
I have a 2 set of carburetor for my 1993 honda cbr 900rr and i dont know which one will be a better fit.. the 93 carburetor look smaller than the 99 carburetor any opinion of which one will be the best fit and also performance wise
Put the 93 in the 93
im thinking to put the 99 carburetor in a 93 engine i took out the sensor of the carburetor and im thinking to jet the carburetor too
i bought a sonic cleaner fro harbor frieght a couple weeks ago and cleaned my 95 carbs with it..
i fell off my bench table, i couldn't believe how clean it came out.. then put them back in and what a difference it made.. i used to use one can after the next of carburator cleaner.. those days are gone... jay |
do tell!!
How did it work out for you?? did you use the 99? |
Originally Posted by jasonchristopher
(Post 1243777)
i fell off my bench table, i couldn't believe how clean it came out.. then put them back in and what a difference it made.. i used to use one can after the next of carburator cleaner.. those days are gone... jay Ultrasonic Cleaner - 2.5 Liter |
yep, thats the one...
if you actually pick that one up, i would also suggest grabbing O-Ring Assortment Pack - 397 Piece Metric O-Ring Assortment since your there.. and what i've noticed.. to get the carburators fully cleaned and sumerged you have to take off at least one off the end.. all four wont fit in at the same time...and if your going to pull them apart you might as well replace what you can.. as i learned when i put everything back and had a fuel leak... and was kicking myself in the butt.. anyway after the sonic bath my carbs got... i felt the power band come back and the bikes snappyness.. which obviuosly saves me from having to change out my "mains".. oh and one last thing.. use simple green instead of water... the dirt/grease just falls off.. i think thats it.. have a good day scutfargas jay |
What carb did you end up using Kennethhodge???
