1994 CBR900RR USA model
Old Jun 4, 2021 | 08:08 PM
AKMHonda's Avatar
Default 1994 CBR900RR USA model
Alright everybody new here but couldn’t find a solution when I searched.
so here’s my issue, my bike feels sluggish and like it’s governed at 115mph. Has new plugs, cleaned filter, carbs went into an ultrasonic bath, and a stage 2 jet kit. I remember not all that long ago I was hitting 160 with a buddy and now it feels like a 250cc. It’s getting fuel and no stutter in any gear or rpm range but it hits 115 and stops. Any ideas?
Old Jun 4, 2021 | 08:22 PM
Hey there If you can, stop by the new member’s area and introduce yourself.
when you put the carbs in the ultrasonic bath, we’re they split apart or as the entire bank? The reason I ask is they absolutely need to be dunked individually. And when this happens they need to be synced afterwards.
Old Jun 5, 2021 | 03:37 AM
AKMHonda's Avatar
They were split apart and resynced. Forgot to add that in.
Old Jun 5, 2021 | 11:13 AM
Have adjusted the height of the needles?
Old Jun 5, 2021 | 10:54 PM
AKMHonda's Avatar
Not since when the jet kit was put in back in 94 when my father bought it new.
Old Jun 6, 2021 | 10:51 AM
Since you had it apart, is it possible that something didn't get put back together all the way? Are all the air hoses connected and not pinched?
Old Jun 6, 2021 | 10:49 PM
AKMHonda's Avatar
I wouldn’t think so, I’ve taken everything off and checked it all several times with no luck.
It really feels as if the bike has a speed limiter since it doesn’t matter the Rpms it just stops at 115.
Old Jun 7, 2021 | 10:57 AM
So you're able to run up to redline in 1st and 2nd with no issue (max speed would theoretically be 95 MPH in second gear), but in 3rd gear it stops accelerating at 115 MPH which is just slightly over 10,000 RPM?
Old Jun 7, 2021 | 06:02 PM
AKMHonda's Avatar
pretty much yes. Doesn’t matter what gear or rpm range it just stops at 115
Old Jun 8, 2021 | 03:55 PM
So it doesn't seem to be an ignition problem since it can rev to redline in 1st and 2nd. Then 3rd, 4th, 5th, and 6th have problems at velocities above 115mph. Seems like an airflow issue. Vacuum slides not opening all the way, or vacuum leak somewhere. During the rebuild of the carbs, "all" O rings were replaced? Have you pulled the tops of the carburetors to verify the vacuum slide skirts are seated properly and not leaking?
