17" front rim
Old Jan 2, 2011 | 03:21 AM
Queaos's Avatar
Default 17" front rim
Hello. I have a 99 900 and am looking to change the 16" front rim to a 17". Does anyone know a compatible bike that will allow me to change without having to make that many changes.
Old Jan 2, 2011 | 03:45 AM
billetproof97's Avatar
not sure but hope another bike would be a direct swap. if not it would seem like waste of time and money.
Old Jan 2, 2011 | 08:02 AM
pepperman's Avatar
A friend of mine has an early model 900RR(not sure of year but it's the tiger blade) that he fitted a VFR750 17" front. I think he swapped over the 900's dics and either had spacers made? Can't remember cause it was a while ago and I now live 1000 miles from where he lives. Hope this kinda helps. He did say it was a huge improvement for front stability and confidence.
Old Jan 2, 2011 | 08:14 AM
pepperman's Avatar
Pretty sure it was a '94. Maybe look into whether or not the VFR800 front wheel fits yours.
Old Jan 2, 2011 | 08:34 AM
pepperman's Avatar
Me again. I typed '99 CBR900RR 17" front wheel into google (not that hard really) and the general consensus is either a CBR600F3 front or a VFR750 front. Speedo drive and spacer issues(if any) but hey, that's what I found.
Old Jan 2, 2011 | 09:05 AM
Queaos's Avatar
Thanks for the info
Old Jan 2, 2011 | 09:23 AM
crzy1laz's Avatar
i have a 99 also keep in mind that 98 and 99 have a wider fork than the other years and the rotors were changed from 295mm to 310mm i was going to do the swap on mine but having hard time getting a for sure answer. but i talked to a guy that has a 98 and he swaped the fork, triple tree, wheel, from a 954 to get the 17in wheel. hope this helps good luck
Old Jan 2, 2011 | 06:32 PM
pepperman's Avatar
I didn't read it all but it looks like your answers are in here somewhere.http://www.fireblades.org/forums/hon...need-help.html
Old Jan 3, 2011 | 09:13 AM
vfrman's Avatar
Party Animal, ROTM June 2014
I don't think any wheels are a direct bolt in. I ended up bolting a 929 front end on my bike. That is a direct swap.
Old Jan 8, 2011 | 09:10 PM
Hondas Rule's Avatar
My 99 900RR had a custom fitted CBR600F3 front wheel and used the CBR1100XX black bird rotors, If you can't find a definate answer here check out Fireblades.org and search for ajdapilot. He did my custom setup and has all the info on firebaldes, It is doable
Good Luck
Jim
Gnarly 928
Apr 23, 2013 11:40 PM
superjuicebox2
Nov 21, 2012 01:13 PM
jun167
Sep 3, 2009 06:06 PM
KenG
CBR1000F For Sale / Found
Aug 9, 2009 05:20 AM
