Wheelie?
Old Jan 8, 2007 | 05:13 AM
brazilianatuh's Avatar
Default Wheelie?
Hey guys, new here, for those who wheelie out there.
Can u give me a few hints, or how to's.
Starting in first gear, just playing around reving and etc... or second gear about 30-35 miles per hour, pull the clutch in let the revs go get as high as...? to then pop the clutch to lift the front? and once i got the front up, is there danger of acclerating and falling back?
any advice or recommendations, thanks.
Old Jan 8, 2007 | 05:37 AM
BlindLOKI's Avatar
Default RE: Wheelie?
um... there are a TON of posts on this, and mainly in the stunters section... but ill help you out real quick. To start off get goin around 10-15 in 1st, slip the clutch and give it gas. when you slip the clutch its just a "rub" in and right back out. its just enough to let you gain revs when your givin it gas. if the wheel doesnt come up, give it more gas in the same amount of time it takes to rub the clutch, simple as that. Now for riding them out, i have no clue yet, im not very good and most people will probably agree. Its all throttle control, and i havnt got that down yet....
good luck,
chris
ps, start small, work your way up, WEAR YOUR GEAR, ANDCOVER THE REAR BRAKE--- could be your life saver
Old Jan 8, 2007 | 11:27 AM
knightslugger's Avatar
and stay off the streets when you wheelie.
Old Jan 8, 2007 | 11:49 AM
TheX's Avatar
ORIGINAL: knightslugger
Best advice ever!!!!
Old Jan 8, 2007 | 06:38 PM
Thanks
shardoflard
Jun 22, 2009 12:28 PM
scorpion2420
Oct 14, 2008 02:58 PM
KingKong
Aug 31, 2006 09:18 PM
stephygee
Aug 19, 2006 02:55 PM
