Volcom's 07 600RR Rebuild - Near Completion
Dont know much about this but someone out there might. If u removed the ecgu motor and valve would u have any service lights come on? i ride the streets with mine and thought all could help with what i have now.
are you trying to do this mod yourself to reduce weight? and also are you talking about the servo motor connected to the EGCV located on your headers? If your talking about the EGCV, yes you can remove that and yes it will throw an FI light.... if you wire the correct colored wires together with a resistor then that will take care of the FI light and everything will be straight.
yeah its not much weight that it looks likes but all can help. i planned on removing the motor under the seat with the valve in the header. But will i lose any top end power or low end? i already added a leo vince slip on which reduced alot of back pressure due to the straight threw design.
Hey I have a question. how did you remove the adjusting nuts(the ones needing a castle-type socket) on the right side of the frame? I did a search and people either made the socket by grinding/cutting or took a hammer and flat head to it.
