Turn Signals
Old Apr 3, 2006 | 05:17 PM
jesterj98's Avatar
Default Turn Signals
I bought aftermarket LED turn signal lights for my fornt and rear, now I have to install a turn flasher relay so my trun signals can blink. but I need to diable and locate the stock flasher relay. Can someone let me know where it is located. its a 2005 CBR 600 RR. thanks for the support.!!!!!
Old Apr 3, 2006 | 11:16 PM
bluerrpilot's Avatar
Default RE: Turn Signals
how come the stock flasher relay wont work?
Old Apr 4, 2006 | 10:58 PM
dreamer25's Avatar
just put LED signals on front and ca integrated on rear, and my stock flasher worked....just had to add the resistors on the taillight so it would flash
Old Apr 4, 2006 | 11:23 PM
doncollins's Avatar
Retired Administrator
I put hot bodies LEDs on the front and clear alternative integrated on the back.... the flash rate was a flicker. They never fully went off. You had to really look to see that they were doing anything. The stock flasher is part of the speedo cluster so good luck trying to remove it. I had to add resistors to my front signals to obtain a fast flash again.
Old Apr 4, 2006 | 11:56 PM
CbrTommy22's Avatar
Had the same problem here some resistors should almost definately fix your problem
Old Apr 5, 2006 | 06:16 PM
bfont23's Avatar
Yeah, but my rear signals stopped blinking when i installed my hotbodies flush mounts... will resistors fix that, too? If so, where the hell can i find them? This is bugging the crap out of me.
Old Apr 6, 2006 | 06:29 AM
josho66's Avatar
Resistors are what you need, work great.
Old Apr 6, 2006 | 09:02 AM
Truckie973's Avatar
resistors will fix the problem promise. it will make both the tail blink and front turn signals blink again normally
Old Apr 10, 2006 | 01:33 AM
cjbettis's Avatar
just remember that resistors don't go in series....you run across the two
Old Apr 10, 2006 | 12:09 PM
MisterBasket's Avatar
I had the same problem. You can put the resistors up front with the front signals or in the back with the taillight. You shouldnt have to put them both front and rear. Good luck trying to find them. Ive gone to hardware stores and auto parts stores with no luck. Try a commerical electrical company or just catch an electrician making repairs in your area cause he might have some on him.
