Sylvania Lights
dose any one know if these will fit in my 06 CBR 600RR and if not can any one give me an idea of what lights to use for around the same price and same light color
Sylvania SilverStar H7 High Performance Halogen Capsulehttp://www.autobarn.net/h7sthipehaca.html
Not sure what you mean about capsule, but it has to have 2 prongs on the bottom to go into the adapter on the Headlight. I can tell what it looks like from the bottom.
Yeah the link is in the first post so if you can please look at that and give your opinion if they will work or not....thank you agian.....
ok just found out and yes they have the two prongs and that will work....the reason i ask is because my girl freinds dad put these same brand lights in his 07 suburban and avalanch.....and they are bright as hell...so if if put them in both high and low beam side and tilt the high alittle bit down i should be great....and is it easy to point the high beam down a little bit....
i would say yes if the 05 takes H7 bulbs....i just ordered them and i dont know how easy it will be to install them. assuming it will be easy. yes you will want to buy two if you want the same bulb in both light houses. i think they only come as one per package.
How many motorcycle riders does it take to screw in a light bulb? It's a frickin' lightbulb [sm=bangbang.gif]hahaha
Disconnect, remove the dust cover, unlatch the clip, swap the lights, do the reverse - done.
Any H7 bulb will work in the 600RRs, just make sure they're 55W bulbs. Anything higher may fry your wiring and electrical system. Justlook atyour headlight housing and all the info for what bulbs you can you use is there.
