Stator cover
Old Jun 23, 2007 | 07:24 PM
rdrink25's Avatar
Default Stator cover
Has anyone ever taken this off if so there are 5 bolts required to loosen and i didnt know if they had to be a specific torque when put back on
Old Jun 23, 2007 | 07:38 PM
Jason748's Avatar
Default RE: Stator cover
Yes, many, many times... But last time I looked there were 8 bolts, not 5.
There is no listed troque spec in the manual, it just states "tighten bolts securely.
BUT, Make sure you remove the old sealent from both the case and the cover (if it's even there), and replace using new sealent (honda-bond. yama-bond, ducati-bond, etc... it's all the same stuff) and don't spread it too thick, you only need a very, very light layer.
Old Jun 23, 2007 | 07:53 PM
rdrink25's Avatar
thanks for the info on the honda bond but i was talking about the 5 bolts that actually hold the stator in place
Old Jun 23, 2007 | 08:12 PM
Jason748's Avatar
Ahh.. The 4 that hold the stator and the 1 that holds the wire clamp in place...
Per the manual:
The 4 stator bolts need to be torqued to: 9 ft-lbs (12 N-m)
The 1 wire clamp bolt needs to be torqued to: 10 ft-lbs (14 N-m).
Here's a hint, put a little Honda-Bond between teh wire grommet and the stator cover...
Old Jun 23, 2007 | 08:25 PM
rdrink25's Avatar
thanks man
Tn929rr
Aug 17, 2007 05:07 PM
