Sprocket question?????
Old 02-17-2006, 02:12 AM
Default RE: Sprocket question?????
ORIGINAL: chainstretcher
What's your stock gearing -- 16/43? If that's right then -1/+2 will put your speedo an additional 11.6% happy
Curious how you came up with that %. Do you have a formula? Have -1 in the front only. Have a sprocket for +1 in the back but **** its hard keeping front end down now, wondering if I should even throw it on.
Old 02-17-2006, 01:03 PM
rubberband man's Avatar
[/quote]
[/quote]
How easy is it to get the from up with only -1. Cause i was leaning towards -1, +2 but i don't want it to bee too much...
Old 02-17-2006, 07:17 PM
In first at 20mph it will come up on a drop of a dime. In second at about 65, one little rock and bam it up like nothin. I might consider +1 in the back later. Right now this is enough for me. By the way, I weigh 210. I'm also on a 1000.
Old 02-17-2006, 07:22 PM
I see. then i think -1, +2 would be pretty good for my 600rr. Anyone else with suggestions/experiance with this mod????
Old 02-17-2006, 07:59 PM
ORIGINAL: rubberband man
imo....why not -1, and -2 for like $50 total and play with each...way less money and can mod out all the time without breaking your chain to do it
Old 02-17-2006, 08:09 PM
Talk to 6hundred_doubleR. He just did -1 on his 600RR and he loves it. He can better tell you what you'll get out of the 600
Old 02-17-2006, 09:11 PM
ORIGINAL: JeffRR
bro...totally worth!!! Don Collins has a -1 and -2 also....totally worth the $22
Old 02-18-2006, 11:44 AM
jwp6114's Avatar
newb question, here's what i would like to do, buy the kit for changing the gearing -1, +2, then change the chain and the front sprocket, i have allways heard that uneven ware by a used sprocket and a new one would cause the new sprocket and the new chain to wear faster. but i was thinking, just change the front sprocket and chain, later on try changeing rear sprocket and put front stock sprocket on, or changeing both depending on which i like best, is this a horible idea, or will the new chain with the -1,+2 kit be too long/short for some any of these combinations, i have allways been with stock gearing. "the newb is not trying to be a retad" just may be asking for too many options at once.
Old 02-18-2006, 12:09 PM
jwp6114's Avatar
although when im laying over the tank and running hard through 1st gear and shift into second it feels like the front tire comes off the ground 3-4 inches, is this normal with stock gearing, i dont do weelies often but i can never get them up in second. im sure it just my technique. "i know weelies are the [sm=badbadbad.gif]"
06 Tribal 600rr
02-07-2013 08:33 PM
irocthestreet
07-09-2009 03:01 PM
Kelo718
04-04-2009 03:19 PM
tillersluck1117
03-19-2007 11:18 AM
mflave007
11-07-2006 04:10 AM
Quick Reply: Sprocket question?????
