Speed in gears..
Old Jul 11, 2005 | 08:50 AM
milletary's Avatar
Default Speed in gears..
Anyone know the max speed per stock gearing?
Specifically I was looking at what the max was for second gear.
Thanks,
Jeff
Old Jul 11, 2005 | 10:53 AM
milletary's Avatar
Default RE: Speed in gears..
Wasn't clear
1st = ?MPH
2nd = ? MPH
3rd = ? MPH
4th = ? MPH
5th = ? MPH
6th = ? MPH
Thanks,
Jeff
Old Jul 11, 2005 | 01:00 PM
johnwoods23's Avatar
I'm not sure, but I'll go play around today and get back to you!
Old Jul 12, 2005 | 01:48 AM
OneWheelinRR's Avatar
Um
1.2.3.4.5.6 - said 178 in about.... 15-20 seconds. No joke. I got 2 down 3 up gearing lol
Highest stock i hit was 174mph. took a while to get there too. And it wouldnt go past. I was going down hill for A DAMN LONG TIME in a straight line and it still wouldnt move.????
Old Jul 12, 2005 | 03:00 AM
abadfish's Avatar
ORIGINAL: OneWheelinRR
Um
Your gearing has definitely affected your top end.
I'm going to assume you don't have a speedo recalibrator (since a stock RR wouldn't hit 178mph). With that gearing, your speedo is off by 23%. So this means that you were actually doing 138mph (more likely to be even less since you probably have a stock speedo error compounding this).
Old Jul 12, 2005 | 07:03 AM
Anubis's Avatar
I agree with that one ^ ^ ^
Old Jul 12, 2005 | 09:42 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Gear Speed Calculator -- I don't know what the values are for your particular model. They'll be in a service manual. Just plug 'em in.
Old Jul 12, 2005 | 10:00 AM
All right -- I found the gearing here -- The Place. They had 6th gear ratio typo -- should be 1.166 not 1.666. I could not find what your limiter is set at so I used 14,000 -- pretty sure it ain't much higher than that.
So here's the breakdown:
1st - 69.1
2nd - 95.1
3rd - 114.35
4th - 130.75
5th - 146.21
6th - 157.99
Old Jul 12, 2005 | 10:17 AM
2 down 3 up yields top speed of only 129.03 mph[:'(]
Old Jul 14, 2005 | 04:19 PM
milletary's Avatar
Sweet, thank all!
