Service manual CBR 2015
Hi everyone, I apologize for my poor English.
I am new to the forum and like you I am the owner of a honda cbr. 😍 Do any of you have the workshop manual for the 600 rr 2015 model? Or can you tell me the tightening of the upper fork plate? I have to mount the handlebars ... Sorry if I got the wrong section! Gassss |
@Gin600rr Hi and welcome to the forum. If you can provide a better description of exactly what bolts you are referring to, I can probably provide that information. Is it on this page?
https://www.partzilla.com/catalog/ho...bar-top-bridge Ciao e benvenuto nel forum. Se puoi fornire una descrizione migliore di esattamente a quali bulloni ti riferisci, probabilmente posso fornire queste informazioni. È in questa pagina? |
@IDoDirt
Sì! I bulloni sono i numeri 22, 24 e quelli esattamente accanto al 24 credo (non sembrano numerati dalla foto)Ma è necessario rimuovere il blocco HISS per rimuovere la piastra? |
That's too funny, I don't speak Italian. I just used Google Translate to try to help. I found information for #22, but I'm not sure what you mean by next to 24.
È troppo divertente, non parlo italiano. Ho appena usato Google Translate per cercare di aiutare. Ho trovato informazioni per il numero 22, ma non sono sicuro di cosa intendi con accanto a 24. Item #22 is actually 22 N m, or 16 lb ft. |
@IDoDirt Yes, I am also using google translate 😂
Those next to 24 are those two little bolts, if I can post a photo to make you understand. Is the number 24 true that it must be closed at 100 Nm? https://cimg5.ibsrv.net/gimg/cbrforu...07060a16c.jpeg |
Those next to 24 are those two little bolts, if I can post a photo to make you understand. Is the number 24 true that it must be closed at 100 Nm? https://cimg3.ibsrv.net/gimg/cbrforu...902760da3.jpeg |
Excellent then, great minds think alike. Posting the photo is perfect. For the 2 Allen Head screws, there are no torque specifications for them. As for the Steering Stem nut, it is 103 N m or 76 lb. ft.
Eccellente quindi, grandi menti pensano allo stesso modo. Postare la foto è perfetto. Per le 2 viti a brugola, non ci sono specifiche di coppia per esse. Per quanto riguarda il dado dello stelo dello sterzo, è 103 N m o 76 lb. ft. |
@IDoDirt Thank you very much, your information is very useful to me.
Last thing I ask you, do you know if the H.I.S.S system must be disassembled to be able to remove the plate? Or does it all slip off together? |
Sorry, I was thinking about the Steering Damper. The US models do not have the H.I.S.S., so I can't speak to that.
Scusa, stavo pensando all'ammortizzatore di sterzo. I modelli statunitensi non hanno l'HISS, quindi non posso parlarne. |
