removing PAIR system..
PC3 required? or reccomended?
RE: removing PAIR system..
what is the PAIR system? emissions control?
if so i would think a PCIII would be a good idea, you might have to custom map though, i am not sure if they have maps for download that would take that into account. |
The PAIR is an acronym for Pulsed Air Induction Reed valve.It injects fresh air from the airbox into the exhaust system to help burn off fuel that was not burned in the pistons. It will cause dyno air sensors to read lean because of the fresh air injected, so it either has to be blocked off orremoved completely to dyno tune the engine. Heybuddy are you going to get a PCIII and a custom map ? Then do this mod....if your not going to get that stuff..I dont see the reason to get the mod done. It removes about a pound of weight....but your not gaining anything performance wise persay. I've seen a couple of arguments that saysit helps performance of the engine marginally by potentially increasing exhaust and intake flow...but thats a pretty tough sell and a lot of work for that "potential" gain.
god damn this site
hey buddy = genius. do it
i have a PCIII and i'm about to get a custom map, after i get this done you think is better to remove the pair?
thats what im trying to deduce..
if its going to be a custom map anyways... ya know? |
do the mod heybuddy...you are perfect candidate. God damn this website [:@][:@][:@][:@]I typed out a whole thing GGGRRRRRRR
Kyle Racing block off plates : http://www.shop.kyleusa.com/product....;productId=106
