"RACCOON TAIL" ***COMPLETED***
17 Attachment(s)
Dial-up warning........LOTS of pictures here.........
Alright guys, here it is. The new "Raccoon Tail" Fender Eliminator. This is a combination of Larry's Fender Tag Bracket, Rizoma Zero LED turn signals (front and rear) and the heat shield cover (fabricated by myself.........which took forever.) Why is is called the "Raccoon Tail"?. Well, the front mask design I did is called the "Raccoon Mask", so I decided to call the rear fender a "Raccoon Tail" for continuity purposes. :D (plus, "Raccoon-ish" reflective decals for the fender are currently being made.) So, I wanted my fender eliminator to address the following issues......... 1. Getting rid of the stock fender 2. Maintaining the stock exhaust, but still hiding the stock heat shield. 3. Mounting the tag. 4. Mounting Rizoma turn signals in rear. Here is a sort of "semi-writeup" with pics and how I did it........ With the mud flap, reflector and tag light removed, you get this, the heat shield cover that has that bit sticking down. I could have left it, but I decided to take my ingenuity and make it my own design....... Attachment 83384 Then I took a hack saw to it (with a design in mind) and went at it......... Attachment 83385 And came up with this.......... Attachment 83386 Now for the test fitting to make sure everything fits and hides everything I want it to...... Attachment 83387 Then after a belt sander, hand sanding, and a nice coat of paint, I came up with this............ Attachment 83388 Now to install the kick-ass Rizoma Zero turn signals.......... Attachment 83389 Attachment 83390 Another test fit and adjustment for the signals, and all the freaking wiring....... Attachment 83391 .......like I said before, FREAKING wiring. I'm really starting to hate wires at this point....... http://i106.photobucket.com/albums/m...48/fender8.jpg AND NOW THE FINISHED PRODUCT!!!!!!! Attachment 83392 Attachment 83393 Attachment 83394 Attachment 83395 Attachment 83396 Attachment 83397 Attachment 83398 I ALSO SWAPPED OUT THE FRONT TURN SIGNALS TOO...... Attachment 83399 Attachment 83400 Let me know what you think. I thought it turned out GREAT for not costing a damn penny (other than the spray paint and Rizoma signals.) |
RE: "RACCOON TAIL" Fender Eliminator
Well, I have to say I am intrugued, and will be watching this space carefully.....
in for dope ****.
THAT LOOKS F*****ING SWEET!!!
where /how much for those riozomas???? Those would look great on the front of the 07 I got the Bikelitez FE, (but I think I'm going to bastardize it with part of your Idea as well) |
looks great, Wanna come up to NYC and do some work on my 04.
nice work my friend much better than the mud flap
Looks good... very good work on your part, but I'm not sure I like the lights. Need to see them in person.
Rizomas look good man!!!!!!! I love those!!! If you want to get rid of the C.A, let me know
wow, looks awesome! you think you will have any problems passing inspection?
ORIGINAL: aaron1085 wow, looks awesome! you think you will have any problems passing inspection? Other than that......I would actually pass inspection with the exception of the signals (which are approved in Europe, but not DOT approved as of yet.) Even if I did have to get it inspected, I would just swap the Rizoma's out for some DOT ones anyway. (and yes, my tag does have a light too.) But I will say one thing, these Rizoma's are FREAKING SWEET!!!! They are MUCH brighter than stock signals (though, they are smaller). And at night, they are VERY VERY VERY much brighter than stock. :D Plus, at night, the entire signal lights up, so you can see them from front/behind/side, etc. |
