Problem NO idea NEED HELP
Old May 29, 2008 | 01:53 PM
lsysfts's Avatar
Default Problem NO idea NEED HELP
my bike stopped running, it turns over and sounds healthy but fuel pumpisn't turning on. I checked the all the fuses and they are all good. I put a multimeter on the plug running to the fuel pump and when you turn the key on you are supposed to get 12v for a couple of seconds and then back down to 0. But i got a steady flow of 10 and doesn't drop back down to 0. This makes me think my pump is shot but at the same time why am im getting a reading of 10v and not 12v and why isn't it dropping back off to 0 after a few seconds. I did check the battery and the battery is giving me a full 12v. I am extremely frustrated a seriously bummed i can't ride. Any help or ideas would be greatly appreciated. Thanks in advance one last thing this all started when I had to replace my front fairings and had to unplug a few plugs but all got plugged back it I have double even triple checked. Since then problem started
Old May 29, 2008 | 02:02 PM
jfunkRR's Avatar
Default RE: Problem NO idea NEED HELP
All ground wires are still intact or any wires being "pinched" by new fairings? I had some electrical problems with my old F4i, and I took the fairings off one day and noticed a wire was "pinched" and it was blowing fuseson me and such...I striaghtened it out and re-taped it and it was fine after that.
Old May 30, 2008 | 05:48 PM
WoodyRR's Avatar
Of course I'm going to state the simplest, easiest thing to check. I hate to be "that guy" but did you check the engine kill switch? Figured I'd throw that out there.
Old May 30, 2008 | 06:22 PM
heybuddy1901's Avatar
did you unhook the battery when you were messing with the connections...
jin27us@yahoo.com
Feb 12, 2013 09:50 AM
Orangebutter
Oct 9, 2008 10:16 AM
jarvis1127
Aug 4, 2008 08:00 AM
cyber00677
Dec 7, 2007 02:55 AM
06cbr600rrguy
Jun 20, 2007 01:50 PM
