Power increase?
My opinion K&n really didnt make much of a diffrence.going up 3 on the back and -1 in front did alot.if you have the cash and your looking for a major increase in power get a turbo charger.I know its costly but once you got it you wouldnt go back.Its like going from an escort to a ferreri.for now I would go with maybe a power commander and a full system exaust. for under a grand and while your at it spend the 60.00 and through the k&n air filter it will make it breath better.
ORIGINAL: fastmofo
My opinion K&n really didnt make much of a diffrence.going up 3 on the back and -1 in front did alot.if you got the loot and your looking for a major increase in power get turbo.I know its costly but once you got it you wouldnt go back.Its like going from an escort to a ferreri.for now I would go with maybe a power commander and a full system exaust. for under a grand and while your at it spend the 60.00 and through the k&n air filter it will make it breatgh better.
Where would you get a turbo at just would like to see how much hp you would get out of it?
ORIGINAL: NINE2NINE
the power commander is really easy to install. and definately the first thing that i would install to increase performace. get the pc3usb and you can download maps from dynojet and install them directly to your bike. check it out. www.powercommander.com
You should be able to tweek a few horses with just a power commander. I also recommend doing your upgrades in phases so you can see the difference with each. After the PC then do a slip on. Then after the slip on if you still want some lower end power gear it -1 in front and +2 in the back.
ORIGINAL: chainstretcher
So is your right hand gonna be able to handle all that extra power? The very best mod on any bike is improving the rider ... just a thought.
Do the best mod and get the rider improvement kit (a track school), and you'll smoke just about any schmuck out there with your under powered RR.
![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
< Message edited by 04CBR600RR -- 12/19/2005 10:36:19 PM >
http://www.sportrider.com/features/146_0004_blow/ is where youlle find the how to's on installing a turbo for your bike. If you do go that route have a competent person do it.
ORIGINAL: 05Tribal
thanks for the tip on the PC first....was going to do slip-on then it...but checking into it
ORIGINAL: fastmofo
wouldn't you just step up to a 1000RR first? less $$$.
