PLEASE HELP 2003 Honda CBR600RR Fuel Pump Won't Prime
Old Apr 3, 2022 | 02:35 AM
608CBR600RR's Avatar
Lightbulb PLEASE HELP 2003 Honda CBR600RR Fuel Pump Won't Prime
So I bought the bike from a local rider, he had said it needed a fuel pump so I figured no problem. Have had it looked at 3 times by 3 different technicians all with different solutions. One said Ecu so Got a new one, another said fuel pump so got a new one, last one said relay but couldn't find a faulty relay. Any help would be greatly appreciated as warmer weather is here and I'd like to be out catching wind with my brothers! Thanks in Advance and Safe Rides!
Old Apr 3, 2022 | 08:07 AM
Moved the thread to the correct sub.
Old Apr 3, 2022 | 12:12 PM
@608CBR600RR Hi and welcome to the forum. On Honda fuel injected bikes there are 2 relays involved with the fuel pump, the Engine Stop relay and the Fuel Cut Relay. Both of these relays are controlled by the Bank Angle Sensor (BAS). The BAS is what provides a ground connection for these 2 relays to work. The BAS is what turns off fuel flow to the engine, if the bike falls over. So, some checking needs to be done using the wiring diagram and a meter to see if these things are working. Did any of the 3 technicians actually do any diagnostics?
Old Apr 3, 2022 | 02:55 PM
The one who stated it needed an Ecu did a run-through with a multimeter, also the 3rd checked all relays. Have went and looked after your reply and seen the BAS(Bank Angle Sensor) is Bypassed. Do I unbypass is and put a new BAS on? Thanks for Your Time and helpfulness.
Old Apr 3, 2022 | 10:56 PM
I don't understand why everyone bypasses it. Here are some questions I have.
When you say the "3rd check all relays", what exactly does that entail? There are 2 specific relays that I mentioned before that will allow power to be provided to the fuel pump. When you turn on the Ignition Key, do those 2 relays turn on? If they do, are the providing the proper voltages to the right destinations, ie, is power getting to the Fuel Pump? Going to need a shop manual and wiring diagram to check these things. Do you have them?
Old Jul 12, 2022 | 10:43 PM
dannoxyz's Avatar
Any progress on this???
Old Jul 12, 2022 | 11:18 PM
I think you'd have to ask @608CBR600RR
Old Jul 13, 2022 | 12:07 AM
dannoxyz's Avatar
@608CBR600RR , did you get this resolved? Most likely those *%#$! relays. They fail when you just look at them wrong. I usually just chop them all off and solder in new sockets for standard Bosch relays. Double capacity (40a) and they're so much more reliable with coated terminals.
Old May 16, 2023 | 05:46 PM
03cbr600rr.rebuild's Avatar
Was you able to figure out what the issue was? Im having the same issue with the bike im rebuilding and i keep reaching dead ends
Old May 16, 2023 | 08:53 PM
dannoxyz's Avatar
There are MANY steps were things can go wrong to cause bike not to start or pump not prime. It can be broken switch, broken wire or broken sensor or bad relay.
Go through this guide and post numbers of each step you measured. The numbers you measured will say exactly what's wrong.
https://www.600rr.net/threads/diy-st...-03-06.589929/
Nameless1896
Jul 14, 2020 06:26 PM
dewey18
Apr 12, 2010 07:22 PM
blakesgst
Oct 1, 2009 11:57 AM
frankinbarnes
Mar 20, 2007 11:56 AM
