oil light ?
Old Jul 9, 2007 | 06:30 PM
Brennan's Avatar
Default oil light ?
well today my low oil pressure light came on, and i dont know why, my bike is not leaking oil and just got an oil change, if any one has any advice that would be great.
Old Jul 9, 2007 | 06:45 PM
champ24's Avatar
Default RE: oil light ?
Your low on oil take it back to whoever changed it. Don't be polite about it either.
Old Jul 9, 2007 | 07:22 PM
Sqrly's Avatar
Check your oil level before taking it back. If its so low you cant see it, call where you had it changed before riding it any more and adding insult to injury.
Old Jul 10, 2007 | 12:18 AM
taymax14's Avatar
for sure check before you keep riding. that's what the light is for.
Old Jul 10, 2007 | 07:06 AM
Brennan's Avatar
the light came on before the oil was changed, and the oil level is fine no fuses are blown
Old Jul 10, 2007 | 02:43 PM
baxsom's Avatar
so is your oil level good?
thats why you should do this stuff yourself,
the idiot may have filledl the oil to the line then didnt ealize that when you crank the bike the filter filling up brings the oil level back down
Old Jul 11, 2007 | 10:35 AM
Brennan's Avatar
yup the oil level is good and there are no leaks just hope this isnt gonna cost me alot
Old Jul 11, 2007 | 12:56 PM
baxsom's Avatar
before you take it to anyone test the sender
the wires might have melted and are grounding out on the body
Old Jul 11, 2007 | 03:34 PM
knightslugger's Avatar
ORIGINAL: baxsom
Solid advice. OPSU is probably either grounding out, or, has come loose. common problem for OPSUs.
Old Jul 11, 2007 | 11:48 PM
MADMN's Avatar
I was looking at the service manual and apparently if the oil light stays on it is also MIL (MALFUNCTION INDICATOR LAMP)
i think you may need to take to your dealer and have it reset.
it's on page 6-8, full codes on 6-12 if anyone is interested
