my custom FE
this would look even better with aftermarket blinkers and exhaust( they are coming) absolutely free and extremely light, only uses reflector mounts and 4 washers!! let me know if you want more details...
hope it worked............
the tag is on the original bracket, cut off middle and right tabs then bend the left tab up and around so the screw is pointing up, then drilll a hole in the bottom rear of your battery box, put the tab bolt up through the battery box hole and use the original nut that held it on the fender..
it can be mounted further forward also, mine is as far back as i could get it so its very visible..
i'm waiting until XMas (next time my wife said I could buy anything for my bike) to get my integrated tail light, but I was going to make my own FE just like you did. I guess great minds think alike! Thanks, at least I know the idea will work.
Here is what I have done until I have time to make something else this winter... basically a piece of aluminum spray painted black that is riveted to the tie down plastic pieces...
[IMG]local://upfiles/8675/D52AA838EC22471A8BAE4BC54833AC93.jpg[/IMG]
mvergara79
Oct 10, 2007 11:36 PM
very intrested to know what you did if you have one
