Liscense Plate Keeps coming off!!
Anyone else having issues with this? I'm on my third plate already, even used zip ties for this one. And to my suprise a lady pulls up next to me this morning on my way to class and tells me it flew off, luckily I was able to find it this time!
RE: Liscense Plate Keeps coming off!!
try loctite on the bolts and a lock washer. you should be able to get them at any hardware store.
good luck |
an apoxy of some sort should work nicely on the nut and bolt combo. always has for me. its just a $hitty time getting apart, but do-able.
i put duct tape over the end of the bolt, so in case it gets loose...it can't fall off. Or do you mean the bracket brakes? cuz mine is broken in 2 out of 3 places...i need to get that fixed asap
APOXY!
zip ties broke? I use one zip tie and one bolt/nut - never lost one yet... weird
APOXY!
or go to the hardware store and see if youc an find a bolt with a small whole on the end of it .. so once you have the bolt tight you can slide a cocter key in it
yea some form of glue, i.e. super/crazy on the nut and bolt. that should do the trick.
Try not going 160MPH to school.
