LIGHT CONVERSION
Old Mar 27, 2007 | 01:43 PM
robinhood74's Avatar
Default LIGHT CONVERSION
Hey Everyone!
Does anyone know where you can find a kit so that you can have both of the lights running for an 2003 RR?
Thanks in advance.
Old Mar 27, 2007 | 01:58 PM
cjp48's Avatar
Default RE: LIGHT CONVERSION
Don't know of any kit that modifies the electronics to do this for you.
I think most people leave the high beam switched on and adjust the angle of each light so you have
two beams pointing the same way, rather than one up and one down.
Old Mar 27, 2007 | 02:15 PM
Sabor600rr's Avatar
There isn't a kit but there is a write up on how to do it,and it connects to the harness so both light would come on. Cant get into the site right now from work. When I get home ,i'll try to post up the link.
Old Mar 27, 2007 | 03:55 PM
dragonium25's Avatar
Little switch on your left handle bar. Flick it with your thumb
Old Mar 27, 2007 | 08:03 PM
Silentalero's Avatar
I still cant see how there would be a kit, its the same bulb/ same voltage, the only difference is the reflection angles of the mirror inside the lens. Just aim your highbeam down and leave the bright on.
Old Mar 27, 2007 | 09:16 PM
castellar's Avatar
i think this is what you're looking for.
http://www.600rr.net/vb/showthread.php?t=58476
thank you nate96 at 600rr.net
Old Mar 28, 2007 | 12:20 AM
06silverRR's Avatar
so are you all sayin http://veiligmotorrijden.com/ wont work for this persons needs?
worked for my honda =)
Old Mar 28, 2007 | 04:27 AM
Blue Fox's Avatar
Retired Moderator
I'm with the others on here that would wonder why there is a kit for turning on both lights. Regardless if you use resistors to dim the bulb, the reflection of the lens is the same......only dimmer. Just adjust the high beam down, flip the switch, and forget it. Keep a small philips screwdriver under the rear seat so if you absolutely NEED a high beam, you can adjust it on the fly in a matter of seconds.
Old Mar 28, 2007 | 10:46 AM
Thanks guys I didn't know you could adjust the high beam lens, I thoughtthat it was in a permanent fixed position. If I knew it was that simple I would have no problems.
Thanks guys!
Old Mar 29, 2007 | 06:26 AM
jchavers_2000's Avatar
I'm just going to get both Hid's and blind the **** out of everyone lol
Mattson
Sep 5, 2012 12:51 PM
Stephens
Jul 30, 2006 01:47 PM
Purez
Oct 18, 2005 02:14 PM
Blue70
Sep 27, 2005 04:47 PM
