Kick stand start
I have no neutral light. I bypassed the kickstand swtch to get it to where I could try and let it warm up and check other things. Now I've got plenty of fuel but no fire except for maybe one spark every now and then. I think I may have fouled the plugs cause she is running super rich from being straight piped. I going to start replacing sensors and all once my bills clear the bank then I gotta do a battery and tire and can hopefully take her for a ride.
Before you go and start replacing stuff trying spraying a little starting fluid down your intake. If it fires then you know you have spark, if it doesn't then take one of your plugs out (leave it attached to the coil pack) and turn it over. If you see the arc then you may have spark but no fuel or your plugs could be fouled. Try cleaning them with some gasoline. And before you do ANYTHING put it back to the way you had it with the kickstand switch in place... try starting it then. If it starts then you know you have some other kill or safety switch that needs to be bypassed.
If I were you I'd put it back to the way you had it and go from there. If you put it back and it doesn't start check plugs and what not, but if that still doesn't fly it's safe to assume you have a defective switch or relay somewhere. Maybe in the ignition (not likely, but a good thing to check) or possibly your neutral safety switch.
Ok I need to pull my neutral switch and clean it off and all make sure its good then I'm going to check fuses and relays for the ignition. The problem started before I bypassed the kickstand. Ill hook it back up and see what happens
