How to remove lower cowl on 09
Preparing to my next solo grease monkey challenge. Can you tell me how I can take off the tabs on the bottom after taking off the tap screw behind it?
IN order to take the lowers of its alot easier to take the whole side off. The interlock so taking one off from the other your most likely gonna break a tab. You still have that PM i sent ya about fairing removal? If not i can go locate it.
I watched the video by CBRGUY how many times. The problem is he already took off the fairings when he made the video. I was taking everything off. I took the snap screw off on the bottom. But I could not figure out how to snap off the tab/clip under. In the video, he said to use flat head screw to push it to take it off. I still had problem which way and where I was supposed to push it to take it off
pookguy88
May 27, 2012 04:37 PM
