How about UP SHIFTING.......
Old 04-20-2006 | 02:05 PM
CMHGUY's Avatar
Default How about UP SHIFTING.......
clutch or no clutch?? Tell your story.......GOOD or bad..
Old 04-20-2006 | 06:19 PM
sodamninsane's Avatar
Default RE: How about UP SHIFTING.......
depends on how your riding... riding hard I either tag the clutch a little bit and slam it, or just blip the throttle and slam it... it's the same either way, you just need to cut torque for a millisecond so you can get it out into the next gear... and uhhh... pop the clutch with the throttle slammed in 2nd and see what happens, it's fun.
Old 04-21-2006 | 04:18 AM
13brsxsrr's Avatar
USE THE CLUTCH AND BE SMOOTH W/ IT.
Old 04-21-2006 | 12:53 PM
steve00ses's Avatar
now what i found about my bike and its might be me..but if i hit redline and use the clutch it seems to not let it engauge right and throws it into neutral. but maybe its me being a noob..goin back to the track wednesday for a lil more practice
Old 04-21-2006 | 05:23 PM
NotSoMellowYellow's Avatar
I use no clutch when I am crusing with only one hand on the bars, I also alternate with clutch and no clutch when rideing hard cant say when I decide to use it and when not mostly when I am going fast and don't want to pull the clutch and rattle the bars. (the little twitch you get when you clutch very fast)
Old 04-21-2006 | 06:21 PM
lang1864's Avatar
so what your saying is that i can shift with no clutch at high RPMs???
J
Old 04-21-2006 | 09:27 PM
yeah you just have to cut the throttle real fast... not very much, just enough to unload the engine...
you can either do that or just tap the clutch, you don't need to pull it in more than 1/4 of an inch...
Old 04-22-2006 | 01:21 AM
mjflagg's Avatar
I apply a little upward pressure the the shift lever, then I roll off the gas a little and bring in the clutch just a little and last let the clutch out and roll on some gas. I try to be as smooth as I can and not spend too much time with the clutch in and the rpm down. I learned this reading something on sportrider.com
The only time I fully engage the clutch is while the bike is stopped, never while doing a gear change. I don't do clutchless shifts.
Old 04-24-2006 | 04:24 PM
patas75's Avatar
If done correctly how will this affect wear on the clutch?
Old 04-24-2006 | 05:02 PM
theredgoose's Avatar
As long as you're smooth with clutchless shifting, I don't think that it has any negative affects. At high RPMs, near the rev limiter, it's a lot smoother than using the clutch. I have two seasons of racing on my current race bike, never use the cluch for upshifting and it's still good.
Quick Reply: How about UP SHIFTING.......
