HID on RR
I am about to get some HIDs for my bike... Does anyone have any suggestions as to how I should install it or where I should put the device on my bike?
RE: HID on RR
ORIGINAL: PunishThis any suggestions as to how I should install it or where I should put the device on my bike? Sorry, I am in a mood apparantly. Seriously though, BlueFox did a sweet write up a while back.....hope it helps. https://cbrforum.com/m_230461/tm.htm |
RE: HID on RR
Hide the two ballast in the little "tray" that are below your headlights.If you look down the front forks you will see what i mean by tray. Its just big enough to squeeze thoseballastin there.Some of the systems are " plug n play " which eliminates running all the wires back to the battery and what not. Most of the kits come with detailed instructions on how to install.
RE: HID on RR
Mmmm HIDs are yummy.
RE: HID on RR
put them in the headlights where normal headlights go..... you may have to take off the front fairing
RE: HID on RR
YEP. I did a write-up. I'm about to update that write-up with HID's that don't have separate igniters (newer HID systems) My roommate has an 06 RR and just ordered a new kit. I'll be installing his, and creating a write up for that.
I'm also (in the next week or so) going to be installing an HID system on my other roommates 07 RR.........and a write up of that will follow as well. So, pretty much, I'm going to be the "Go-to-guy" for HID installation questions. I'll let everyone know once I get the new write-ups done. |
RE: HID on RR
ORIGINAL: tytyguy put them in the headlights where normal headlights go..... you may have to take off the front fairing HID's (High Intensity Discharge) are what you usually find in BMW's, Lexus, Mercedes, Audi's, etc. and have a very clean, pure-white light output that is much brighter than regular halogen headlights. |
