HELP HELP
Old Jun 7, 2007 | 05:57 PM
scubba369's Avatar
Default HELP HELP
Yes im new here but hopefully someone can help. I have a 03 600RR and im having problems with it starting sometimes. If the bikes sits for a week or a month theres no problem but say that im riding for a little then i shut it off and try to start it back upmaybe/sometimes i will get one crank out of it then nothing but if i wait a few hours starts back up like new. I had the battery tested they said the battery was good but its not the correct size. So before i go and buy the correct one is there anything else that it maybe?? please someone help me with this!
Old Jun 7, 2007 | 06:03 PM
tomp's Avatar
Default RE: HELP HELP
Having the correct battery would probably help out allot. I'd go buy a battery tender and let it charge, they work great. But with the wrong battery you'll just keep killing it.
Old Jun 7, 2007 | 06:06 PM
Ludefreak's Avatar
Yea if you got the wrong battery, you should get the right on put in and see what happens probly fix the problem if not come back ask guestion again... doesnt do any good to try other solutions if at first you runnin wrong battery.. Good luck
Old Jun 7, 2007 | 07:27 PM
thekid_600rr's Avatar
I would also check every little conection something might be lose somewhere there are so many little conectors and things also check your fuse's because there might not be one blown my lose or something check those to. Good luck
Old Jun 8, 2007 | 06:50 AM
CBRFREEK's Avatar
The right battery will solve your problem....guaranteed
Old Jun 8, 2007 | 09:24 PM
scubba369's Avatar
ok so it sounds like everyone thinks that i need to buy a new battery to solve my problem. Well thanks to everyone and i'll see what happens
