help 07 600rr throwing code 34
The service manual says its most likely a EGCV POT high or low voltage malfunction that might be caused by a loose connection.
Check the EGCV connector under the seat. If it's loose its an easy fix. If not then you'd have to do some tedious troubleshooting which I have no experience with. The EGCV is shown below.
![](http://photoshare.shaw.ca/image/c/e/a/95418/egcv-0.jpg?rev=0)
EDIT: Go to this thread and send Billy Goat a Private Message. He'll send you a link to the Service Manual if you want one.
http://www.600rr.net/vb/showthread.p...service+manual
