headlight adjustment
Old Feb 5, 2008 | 06:00 AM
az cbr 1's Avatar
Default headlight adjustment
So stoked as I just picked up a 2007 600rr. I'd like to raise the low beam a tad and lower the high beam so the light pattern is even like I did on my f4i. I'm sure it's simple but I couldn't locate any adjustment screws like on the f4i?
If anyone can let me know that would be GREAT...
Old May 3, 2008 | 06:33 PM
redrocket08's Avatar
Default RE: headlight adjustment
Just adjusted mine on my 08 600. You only need to adjust the high beam down. The screw is to the upper left of the headlight housing if you are sitting on the bike. It's partially hidden but you don't need to remove anything to get at it. It looks like a bolt with philips screw in the middle. There is another screw that looks the same in the lower right of the housing that controls left to right movement. Let me know if you still can't find it and I'll post a pic.
Old May 4, 2008 | 09:26 AM
odysseyzray's Avatar
I'm trying to do the same thing 2, cant find it tho. A pic would be greatly appreciated, thx
Old May 4, 2008 | 09:51 AM
Cubllsu8338's Avatar
I have an 03 and I need to move my low beam a bit higher. It points about 3 feet in front of me. Where is the adjustment screw?
Griffin
Oct 3, 2007 10:13 PM
Mpolitan0
Apr 7, 2007 10:25 PM
caddy39
Apr 5, 2007 02:40 AM
ekathryn86
Apr 6, 2006 05:55 PM
cjbettis
Nov 13, 2005 11:43 PM
