headlight
Ya is it the head light or the third eye above them if it is the headlight went out and the high beam dose not work either go to the switch housing with the RUN/STOP switch in it. Take it apart and look at the wires one of them most likely broke loose and needs to be sotered back on. if all the wires are still attached it might be your headlight relay which is in between your headlights behind your headlight cowl. Good luck
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
