Gauge cluster HELP
Old Oct 5, 2010 | 11:15 PM
danl23880's Avatar
Default Gauge cluster HELP
This is my issue.
I own a 2006 cbr 600 and the main gauge cluster right blinker will not flash. All lights and blinkers on bike work perfect. The left blinker on the gauge along with all other lights work perfect as well. The only thing is the right blinker on the gauge does not blink to let me know the blinkers are still left on.
I recently had all bulbs replaced by bluegauges and the problem is still not fixed. (this was an issue before i got bulbs replaced and when i did still no change)
I retraced all wiring and all is correct. I used an ohmmeter and have power all the way right where the main gauge is plugged in on the front fairing.
I am assuming it is the gauge sense i have power all the way to the gauge.
I rode the bike 3 days ago and the right blinker on the gauge (problem) was working for about 5 sec then it stopped. This has happened i would say once a month when i ride. HERE YOU WOULD THINK ITS WIRING OR SHORT SOMEWHERE BUT I CHECKED EVERYTHING AND HAD MY DADS BUDDY AN ELECTRICION TRACE EVERYTHING AND ALL IS GOOD. SO I KNOW IT IS NOT A BULB OR THE WIRING.
I AM SO LOST ANYONE AND ANY IDEAS ARE MOST APPRECIATED. I HAVE BEEN GOING AT THIS FOREVER AND HAVE NOT SOLVED ISSUE.
Old Oct 5, 2010 | 11:30 PM
johnnyh's Avatar
If you have current all the way to the gauge the your problem is the gauge. Buy a gaugeon ebay for about a hundred bucks. Johnnyh
Edward Tristram
F2 Tech
Jun 27, 2012 04:20 AM
jestr
Jul 20, 2008 06:40 PM
