fuel injection + exhuast
I was curious if the newer FI bikescan compensate for lean/rich conditions? Anything carbed you put exhaust on runs lean after wards and the bikes that are FI but have no O2 sensor to adjust air/fuel( except cali ), so whats the effect of A/F ratioof throwing/ modding an exhaust on these? Does it work off of MAP or MAF sensors to adjust fuelor does it not compensate?
RE: fuel injection + exhuast
I'm not sure on the tech aspect of this, but I know that moding will lean your bike out. I placed on a Two Brothers slip on andthe ECU does read this and I believe tries to counter it. The stock ECU does not vary it much though. I had some diagnostics done on mine when I was having problems and the sheet showed that I was within the "operational range" but on the very edge of the lean side.
Anything more, and they saidI'll have to use a Power Commander to get back to where the engine needs to be. Hope this helps.
