Front Wobble
Old Apr 30, 2007 | 10:39 PM
sweetbro's Avatar
Default Front Wobble
Anyone know what would cause my handlebars to wobble back and forth quickly when deaccellerating. This is especially true when coming off of freeway off-ramps and I only experience it when I let go of the handlebars.
Old Apr 30, 2007 | 11:16 PM
tomp's Avatar
Default RE: Front Wobble
Both hands off the handlebar? Dose it do it when you have your hands on the handlebars?
Old May 1, 2007 | 01:57 AM
transambird_2000's Avatar
my uneducated opionion would be a bad front tire. when you break it throws a bigger foot print on the ground. If the tire has worn wrong it could cause problems. That would be were i would look first. Google it.
Old May 1, 2007 | 02:41 AM
CBRFREEK's Avatar
Or could be your wheel weight has moved....have it checked out asap...have dealer balance it...
Old May 1, 2007 | 04:19 AM
dragonium25's Avatar
Or try keeping your hands on the handlebars
Old May 1, 2007 | 08:03 PM
Fretless33's Avatar
Bad tire
Wheelout of balance
Bent rim
Old May 2, 2007 | 12:18 AM
Jeff22's Avatar
mine was doing the same thing until i changed my front tire....it had a knot in it from sitting over the winter so long...
Old May 2, 2007 | 06:52 PM
knightslugger's Avatar
ORIGINAL: Fretless33
Bad tire
Wheelout of balance
Bent rim
poor alignment
bad head bering
beefed rotor
Old May 2, 2007 | 07:55 PM
alekinci's Avatar
bent rim is a common answer to that issue...
seperate question.
how high is the rmps when you come of the highway?
Old May 3, 2007 | 12:45 AM
Fretless33's Avatar
ORIGINAL: knightslugger
beefed rotor
A rotor wouldn't only be when he takes his hands off the clip-ons...
DANE-GER
Apr 13, 2011 06:03 AM
trackjunkie08
Sep 4, 2009 09:13 PM
kiai
Aug 12, 2008 11:27 AM
nrok2118
Aug 9, 2007 03:27 PM
forx
Mar 11, 2007 10:28 AM
