Flush mount signals
Old Aug 4, 2007 | 08:56 AM
TXCBR07's Avatar
Default Flush mount signals
Needing some help on this. I like the looks of the flush mount signals but wanted opinions on if you believe them "safe" enough for the streets. Have read some posts saying they are sometimes brighter. That said, any ideas on what would work best on a 07? Where to buy, etc. I did a Google search but was overwhelmed by all the choices. Any help from you experts out there would be a huge help! Thanks.
Old Aug 4, 2007 | 09:37 AM
knightslugger's Avatar
Default RE: Flush mount signals
the safest is stock. Reason being is that they afford enough illumination from any angle to both a. tell other drivers your intentions and b. to let other driver judge your distance from themselves. it is very difficult to judge how far away something is with just one point of reference (the headlight). it's far easier to judge distance with two points (two lights spaced far enough apart to differentiate the two as seperate).
but that all doesn't concern you as much as you thought it did, i HIGHLY recommend Proton Flush Mounts. very high quality, pretty darn bright, and have both running light and turn signal interface.
Old Aug 4, 2007 | 09:52 AM
TXCBR07's Avatar
Thanks for the info. I tend to side with staying as safe as possible - I've just started looking into flush mounts and am looking to gather some opinions. VERY much appreciated!
Old Aug 4, 2007 | 10:35 AM
lilgeneser's Avatar
i got the flush mounts from bike litez on ebay i love em they are way brighter u have to do a lil custom work to have them stick out to see but use ur hand signals to it looks good
Old Aug 5, 2007 | 02:43 AM
eee4666's Avatar
ORIGINAL: knightslugger
I agree 100%
I just installed mine a week ago on my 07. I like them better than some on the market because they kind of "bubble" out of the faring just enough to be seen from all angles, including the front. Some others that are out are a little recessed into the faring which brings down their visibility alot. They also have the running light, they are bright, and lastly, when you're wiring them up you have three blink patterns to choose from:
1.) A fast strobe effect
2.) normal blinking
3.) A slow fade in and out
Old Aug 5, 2007 | 07:52 AM
TXCBR07's Avatar
Thanks for the advice/info. Went with the Proton brand. Will update after the install.
Desertfox223
Sep 12, 2011 09:37 PM
trmoney24
Dec 6, 2010 03:45 PM
JONATHANGT
May 11, 2008 10:13 PM
simyson97F3
Aug 28, 2006 05:09 PM
jlong
Jun 30, 2006 01:15 PM
