fender eliminator...lights wont flash
Old Feb 23, 2007 | 07:01 PM
chuckle1316's Avatar
Default fender eliminator...lights wont flash
hey,
i just put my fe on and the lights wont flash...all they do is light up. i have led front lights too. blown fuse? too fast leds? wiring? please help.
Old Feb 23, 2007 | 07:25 PM
dragonium25's Avatar
Default RE: fender eliminator...lights wont flash
Resistors...do a search
Old Feb 23, 2007 | 11:58 PM
D2VW14_20's Avatar
Make sure your bike is STARTED when you try, not just the key in the on position
Old Feb 25, 2007 | 01:19 AM
tmagness's Avatar
go down to your local bike shop and pick up 2 resistors, place on the line for your blinker. They may blink faster than stock, but its nothing you can't learn to live with. The hardest part is finding a place to put them. good luck
Old Feb 26, 2007 | 03:30 PM
salandagnus's Avatar
you need resistors up front cause of the leds. if you want them to blink at a normal rate, use resistors on the back also. make sure the wires are connected right also, sounds silly but i made that mistake and took forever to figure out, cause i "thought" they were correct. good luck.
Old Feb 26, 2007 | 04:12 PM
knightslugger's Avatar
JSYKFFR, The resistors go on in series, not parallel.
Connect one end of the resistor to the positive wire, and the other to the negitive wire. then attach the signal as normal.
God i hope this works... Please see illustration below.
R \
E \+++++ Signal Positive
S
I
S
T /-------- Signal Negitive
O /
R /
Old Feb 26, 2007 | 06:38 PM
thank you everybody, i will have to try that.
Old Mar 11, 2007 | 11:05 PM
I got the resistors and it slowed the signal down...so it works! but i can't find a good spot for the resistors...if you have resistors please give me a hint of where i can put them. thanks.
cmgeng
How-To: Mechanical
Aug 17, 2009 11:01 PM
apcycles
May 5, 2009 11:15 PM
theisen61287
Jul 6, 2006 02:05 AM
theisen61287
Jul 6, 2006 01:35 AM
smokinclutch8
May 18, 2006 04:28 AM
