fairing help
Old Oct 14, 2008 | 06:30 PM
sk8rat's Avatar
Default fairing help
Well idk whats up but my mid fairing will not stay in the tabs when im riding it just flaps right off and idk what to do can anybody pleaze help me
Old Oct 14, 2008 | 10:31 PM
tomp's Avatar
Default RE: fairing help
Write this up better so we can help you, cause from that...(IDK). Are you missing hardware? What year is it?
Old Oct 15, 2008 | 01:52 AM
skitzofrenzy's Avatar
no bolts??? im confused
AMBIGUOUS
Old Oct 15, 2008 | 05:08 PM
sk8rat's Avatar
i have an 08 and yes i have all the bolts its like when i get up to a certain speed they just pop out of the holes
Old Oct 15, 2008 | 06:53 PM
Frilldog's Avatar
Isthe rubber grommet getting pushed/pulled out? Try some teflon tape or something to keep it from pushing through.
The allan bolt point closest to the seat for the farings, just bolts the 2 plastics together and doesn't secure into frame of the bike or anything solid.
Old Oct 15, 2008 | 10:49 PM
Blue Fox's Avatar
Retired Moderator
If it's the mid fairings on the side of the bike, there's three bolts that screw into rubber well-grommets. Those rubber well-grommets "swell" as you screw them in, preventing them from "popping out".
The top grommet should be attached to the metal bracket, the middle one is attached to the lower fairing, and the bottom one is also attached to the lower fairing. The bolt needs to be tight, and you should be able to tug on the fairings and they should not pull apart at all. If they do, those rubber well-grommets are not seated correctly, or you somehow don't have it tight enough. I'm not sure, a picture would help A LOT.
Old Oct 15, 2008 | 11:04 PM
sk8rat's Avatar
i will post a pic tomorrow
Old Oct 20, 2008 | 04:19 PM
sk8rat's Avatar
LINK REMOVED
MOD: Dude, WTF was up with that link? It started asking me to start a spyware scan on my computer.
kray923
Mar 17, 2009 10:11 AM
