Extended Swing Arms & Lowered 600rr's
Old Aug 17, 2006 | 12:24 AM
FlatBlackCBR600RR's Avatar
Default Extended Swing Arms & Lowered 600rr's
Do they really take much away from your turning performance? And if so...by how much?
Old Aug 17, 2006 | 01:09 AM
knightslugger's Avatar
Default RE: Extended Swing Arms & Lowered 600rr's
yes, they really do. so much so that i'd be a little leary about taking one through the twisites. extended swing arms are for straightline riders mostly. track? forget it.
woodyracing's Avatar
yes
a lot
Old Aug 17, 2006 | 01:16 AM
How about lowering it about an inch or two... i mean a stock 600rr?
Old Aug 17, 2006 | 01:17 AM
cbr_racin123's Avatar
Extended no. But being lowered yes. Most people have never rode a extended bike. Rides fine and turns good. If you are not a knee dragger then yes you can ride a extended swingarm in most places.. But if you are dragger or want to be then don't do either. The key when lowering a bike is lowering the front and rear. But look at it this way. When you lower the bike you can't lean it over as much. Instead of dragging knees you will be dragging the bike.
Old Aug 17, 2006 | 02:15 AM
CBRFREEK's Avatar
BAH...they lower Busa's and Gixxers..but we dont lower RR's..thats why they call em Race Replica's...its just not prudent.
Old Aug 17, 2006 | 02:24 AM
cbr_nasty's Avatar
Just out of curiousity why would you want to do that to your bike anyway ? for the looks of it ?
Old Aug 17, 2006 | 04:22 AM
RojerLockless's Avatar
Extending your bike will make it turn way crappier... and lowering your bike will throw off the center of gravity causing your bike to suck.
Old Aug 17, 2006 | 05:14 AM
dwhite645's Avatar
ORIGINAL: RojerLockless
Couldn't have said it better myself
Old Aug 17, 2006 | 06:01 AM
NINE2NINE's Avatar
Retired Mod
to properly lower your bike, you also have to stiffen up the suspension to keep it from bottoming. so not only will you drag parts sooner, but the ride will also be harsher. the lower the ride the more bone-jarring it will need to be. but that's all the bolt-on links/sliding the forks up lowering kits. having the bike professionally lowered is another story and i have no experience or knowledge in that area but i assume the tradeoff would be similar.
stretching your bike is not as serious of an affect. a longer wheelbase makes your turning radius larger, nothing more and nothing less. will it still turn? yes. will it turn as sharply as a stock length swingarm? no. you can still lean it over just as far (as long as the ride height is stock).
stretching/lowering is great for drag racing. that is what it was meant for and it does that very well. but every advantage comes at a compromising disadvantage. and that disadvantage is a smaller lean angle and less-than precise handling.
