Differences in the 08 from the 07!!!
Old Sep 11, 2007 | 12:18 PM
isolated1523's Avatar
Retired Super Moderator
Default RE: Differences in the 08 from the 07!!!
So wait---you guys are tellin me that they ADDED 40 LBS to the bike for 08???? Might wanna check that again....
-Adam
Old Sep 11, 2007 | 12:24 PM
From the Honda website....
2007:
Engine Type599cc liquid-cooled inline four-cylinderBore and Stroke67mm x 42.5mmCompression Ratio12.2:1Valve TrainDOHC; four valves per cylinderCarburetionDual Stage Fuel Injection (DSFI)IgnitionComputer-controlled digital transistorized with three-dimensional mappingDRIVE TRAIN
TransmissionClose-ratio six-speedFinal Drive#525 O-ring-sealed chainCHASSIS / SUSPENSION / BRAKES
Front Suspension41mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travelRear SuspensionUnit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability; 5.1 inches travelFront BrakesDual radial-mounted four-piston calipers with 310mm discsRear BrakeSingle 220mm discFront Tire120/70ZR-17 radialRear Tire180/55ZR-17 radialDIMENSIONS
Rake23.7 degreesTrail96.3mm (3.8 inches)WheelbaseTBDSeat Height32.3 inchesDry Weight345 poundsFuel Capacity4.8 gallons, including 0.9-gallon reser
2008:
Engine Type599cc liquid-cooled inline four-cylinderBore and Stroke67mm x 42.5mmCompression Ratio12.2:1Valve TrainDOHC; four valves per cylinderCarburetionDual Stage Fuel Injection (DSFI) with 40mm throttle bodies, Denso 12-hole injectorsIgnitionComputer-controlled digital transistorized with three-dimensional mappingDRIVE TRAIN
TransmissionClose-ratio six-speedFinal Drive#525 O-ring chain[IMG]h
Old Sep 11, 2007 | 12:26 PM
Sombeitch's Avatar
Adding 40lbs to a 600 in one year span does not make much sense to me at all. Is this 100% correct?
Old Sep 11, 2007 | 04:56 PM
eee4666's Avatar
ORIGINAL: Frizzle
wish they had kept white.....
when it comes time for me to buy myself a bike its either going to be the 07 pearl white or the 08 in black
haha I'm actually happy they stoped it. Now not AS many people will have it
Old Sep 11, 2007 | 05:37 PM
Gville George's Avatar
I dont see why the orange didnt come with a black fairing. they should give mix and match options. like you want an all silver bike or an all black bike (not a problem with the 08s)
Old Sep 11, 2007 | 06:22 PM
crashkhanman's Avatar
dry weight on the '07 is 345 .. a gallon of gas weights anywhere between 5.8 - 6.5 pounds. Don't forget to include your oil, brake fluid, and radiator fluid. That will give you the weight of the '07. Not a 40 pounds difference. Thanks isolated1523.
Old Sep 11, 2007 | 10:14 PM
PICsuspect's Avatar
Whoa, I only posted this this morning and all this feedback already? D@mn! Well, the weight has only changed 3.5 lbs. Check the hondanews site. The 08 is 3.5 lbs heavier. Not that much of a difference.
Also, the silver fairing's. What's up with that!? I think the silver fairing's look uber gay. Yes I did just say "uber". lol. I think they should do one of two things, either make all the fairings black from the start. Or give you the option, when you are buying the bike, to have them silver or black or any other option of color. I, personally, would do take the red 08 and do this with the colors: switch the initial red to black and the initial black to white. I think that would be oh so sexy.
Old Sep 14, 2007 | 04:50 PM
aaron1085's Avatar
i love that orange..wow!
Old Sep 14, 2007 | 09:05 PM
Slyncka's Avatar
The red really doesnt look the same way it does in that honda photo for the 07. It looks pretty sharp and isnt as pink as it is in that picture.
Old Sep 17, 2007 | 01:33 AM
NeverL8's Avatar
i need to know because i was planning to get an 08 6 for the track...
