crashed my '05 rr and now doesnt want to turn on! any help Appreciated!
Old Sep 28, 2008 | 06:59 PM
abdelito14's Avatar
Default crashed my '05 rr and now doesnt want to turn on! any help Appreciated!
So like the title says, i was heading to school on the 75 and the lady in front of my slams on her brakes! i do the same and vere off into the emergency lane and before i know it she does the same! so im in a full endo and pull back towards the lane but couldnt make it so i hit the back of her car head on and go flying! when i finally got the bike back at the house me and my buddy took her apart and tried to kick start her but to no avail! she turns on, studders and dies. Sounds like shes drowned in gas! any input would help! the crash was at aproximately 35-40 after i was fully on the brakes please help! ty
[align=left] [/align]
Old Sep 28, 2008 | 07:48 PM
Joe06RR's Avatar
Default RE: crashed my '05 rr and now doesnt want to turn on! any help Appreciated!
Sounds like your tip over sensor...make sure that it's still in the upright position mounted on the headlight. Try disconnecting the battery to reset it, it should have reset on its own but just in case.
Old Sep 28, 2008 | 09:23 PM
D2VW14_20's Avatar
If its turning on at all it isnt the sensor.
Old Sep 28, 2008 | 09:51 PM
abdelito14's Avatar
complete front fascia and plastics, gauges and lights are off! just the tank and seat. anymore ideas? need to get this baby running!
Old Sep 28, 2008 | 09:56 PM
D2VW14_20's Avatar
Well your gauge has to be connected to start. Disconnect and reconnect cables, check fuel lines. picture might help us. Kind of hard to diagnose without seing what you are dealing with.
Old Sep 28, 2008 | 11:31 PM
abdelito14's Avatar
awsome ill do that and ill get some pics up tomorow! thanks
Old Sep 29, 2008 | 12:16 AM
Xuracing's Avatar
if your fuel pump is priming its not the tip sensors. Pictures would help!
Old Sep 29, 2008 | 12:38 PM
abdelito14's Avatar
ORIGINAL: Xuracing
fuel pump priming is that little sounds as you switch the engine turn on button right?
if it is im not hearing that
Old Sep 29, 2008 | 07:36 PM
Joe06RR's Avatar
ORIGINAL: D2DGraphix_600RR
I'm curious to see what it is then.
I worked on a 06 GSXR1K 2 weeks ago that had cosmetic damage from going down, after getting it back together I wanted to road test it, it would start and run for 2-3 seconds and shut down. I checked everything and finally looked for the tip sensor which was in the tail section, and there it was laying on it's side. Put it back in place and low and behold...it ran perfect.
Old Sep 30, 2008 | 03:39 PM
abdelito14's Avatar
where is the tip over sensor??
