Comfort
RE: Comfort
I'm 48 & can ride for hours on my RR. But I have a "saddle experienced" butt!! I rode & raced bicycles for years - including a ride across the USA.
So there's your answer. Put in about 2000 miles on a typical bicycle seat & you'll want to sleep on your RR seat!!!
Seriously, I employ the same techniques I did riding bicycles. Move around alot. Change positions frequently. Stretch. Get lightly outta the saddle often. It's all about relieving pressure points.
Now here's a real tip!! Buy some high quality lycra biking shorts with built in chamois padding!! Ride with those on UNDER your leathers and/or jeans, like your undies, etc. You might try this especially until you develop more endurance on the RR.
RE: Comfort
Zo6 !!!! Suave under roo's... my butt thanks you, ahead of time !!!!! Since were sort of on the subject... I wear Hind, silk, underarmour... and a half a kilo of baby powder, w/ ea. what works best to protect from the dreaded prickly heat, sweaty, "I'm jump'n off at 70mph.,discomfort. or will my new chamois roo's cure all hints of distraction?????? I consider what you've put your butt thru... deseving of a medal, and advice of the most qualified caliber !!!!!!! Thanks. Clean and free. Ripp'n ( I already have 3 Corbins)
RE: Comfort
ORIGINAL: rippn
I think you'll find some real help with the bike shorts approach. There's no ultimate cure except to put in the miles & build up the tolerance, but...I mean --- BUTT I mean , the chomois 'roos will certainly help you build up your buttodometer
RE: Comfort
Sweet ride this weekend. Went down to Destin, FL with my friends and rode around there for awhile. I think I put about 350 miles on my bike and my **** this weekend! Didn't have a chance to get the bike shorts before we left, though.
My next comfort isssue addresses the high freq vibrations you get on your throttle hand. My hand was pretty much asleep after about 15 miles or so. I have two kinds of gloves and tried both. I used a gel pad glove and that actually made things worse. Does anyone have a techinque or tip for eliminating this? Thanks!
RE: Comfort
relax, loosen up, loosen ur grip-and just like ur ars move it around alittle bit if you can!!! with me it used to go numb sometimes after 10 min or could be an hour, didn`t think much of it just tought still getting use to it till the first time i gave my kids a ride on it---I WAS SO TENSE AND HELD ON SO TIGHT THAT I NUMBED UP IN LESS THAN 2 MIN---and had to break after fist ride.anyway to get to the point it bearly takes any pressure to twist,just adjust when fast accrleration
thing is backwards sorry
