Chain Wax or Lube?
Old May 2, 2006 | 08:56 PM
techdog's Avatar
Default Chain Wax or Lube?
I bought some new lube for my chain yesterday and I got a big diatribe from the shop on Wax vs. Lube. I normally use my buddies and he has wax. I went in and asked for was but left with lube. What do you all use?
Old May 2, 2006 | 09:57 PM
kiggy74's Avatar
Default RE: Chain Wax or Lube?
Mmmmmmm...... bacon.
Old May 2, 2006 | 10:00 PM
Tahoe SC's Avatar
ahhahha...i use wax...belray...goes on clear...dries white so i know where it is...very little fling...
Old May 2, 2006 | 10:58 PM
smarterben's Avatar
i use lube.....is there a difference using wax??? would you wax less than lube??
all i know is that with the lube...i do it religiously......
Old May 3, 2006 | 12:26 AM
BBLineBacker81's Avatar
rumor has it that wax is a whole lot cleaner, but thats a rumor
-berg
Old May 3, 2006 | 11:28 AM
CYCDUP's Avatar
WD-40 spray after every wash
Old May 3, 2006 | 11:57 AM
Fretless33's Avatar
ORIGINAL: CYCDUP
I hope you lube your chain after you use that WD-40 because it's not really a lube...it's a cleaner...
I use Honda spray lube...
Old May 3, 2006 | 11:45 PM
mjflagg's Avatar
My brother uses wax cause its not so messy. My buddy has an SV that he uses lube and has got so far 25k miles out of the chain. He had used wax before and his chain was short lived. Personally I use lube. I'd rather keep my chain for a while.
Old May 4, 2006 | 08:49 AM
USAF~AMMO's Avatar
I prefer wax,
A) Not as messy, does not get slung all over the place
B) Dirt sticks to lube and WD-$0 in a bad way and once wax dries about nothing will stick to it.
I am not a professional mechinic though!
Bacon grease would smell better on those warm days
Old May 4, 2006 | 11:16 PM
Turboedsupe's Avatar
I use white lithium grease
