CAR OIL
RE: CAR OIL
no on sportbikes the clutch uses the same oil as the engine, and car oil is not made to be used in a clutch, not sure about the technical stuff but the answer is a definite NO, really bad idea
the bike might be okay, but unless your completely out of other options, stick with motorcycle oil
RE: CAR OIL
ORIGINAL: woodyracing
+1, special agents to aid in lubricating the clutch. Don't know how you've used it so long CBR600RRBLUE w/out smoking clutches.
RE: CAR OIL
The special agents in motorcycle oil protect and reduce the mechanical wear within the bike. They are specifically made for bikes and aren't marketing hypes. You could use car oil in bikes, but they aren't designed for bikes. Just like you could use 87 instead of 93 on highly tuned engines, it'll work... just not recommended.
