bleeding brakes NEED HELP
i am trying to bleed my brakes in the front. off the rotor they close all the way and tighten up but on the rotor they get tight but the lever is still loose. does anyone know how i can fix this if so please let me know thanks
Did you check the adjuster on the brake lever? There is a dial with numbers 1-6 on the lever. You may want to adjust that and test it out because that would be the simplest thing it could be.
HAd problems when I installed my Galfer lines on my F4i. A friend taught me to run tubing from the bleeder screw to a cup of brake fluid. Then pump them and bleed them as normal. Got a much better feel way faster. Also, make sure you are using the proper fluid.
