Bad shifting noise!!
Old Mar 27, 2008 | 07:07 PM
Martin_D's Avatar
Default Bad shifting noise!!
I got a little problem guys. When I was riding today when I shifted into 4th it had a clunky type noise. It did it like 3 clicks then went into gear. This is the second time this has happened!!!
Im not sure what to do. It only does it on the upshift, never down shifting. And it only does it like every once in a while.
When it did it today it just did it the once, i shifted into 5th, then 6th, and back down then went through the gears several times, and never did it again. Could it be a loose chain or something? any help please
Thanks guys
-Martin
Old Mar 27, 2008 | 07:56 PM
Red600RR's Avatar
Default RE: Bad shifting noise!!
Have you touched the shifter since you bought it? I had the same clunk after i re-installed the shifter linkage after painting it. You have to align the arm slit with the punch mark on the gearshift spindle. It was slightly off for me....re-aligned it and the "clunk" shifting problem went away.
Hope that helps
RED [sm=smiley20.gif]
Old Mar 27, 2008 | 07:59 PM
Martin_D's Avatar
Its the original shifter and everything. only 300 miles on her [:@]
Old Mar 27, 2008 | 09:27 PM
D2VW14_20's Avatar
Has it happened since then? You may have shifted early or something ans jammed it and then it clunked in and realigned
Old Mar 27, 2008 | 09:42 PM
odysseyzray's Avatar
I noticed the same bad shifting noise too on my bike here. Whereshould i align thosethings u're talking about guys ?
Old Mar 28, 2008 | 07:27 PM
Hatebreed's Avatar
is the clutch cable being pinched anywhere?
Old Mar 29, 2008 | 12:35 AM
Blue Fox's Avatar
Retired Moderator
I think a big question here is are you shifting with riding boots or regular shoes. I will admit that when I ride with regular shoes, I seem to click the gear shifter softer than with my boots. Therefore I sometimes miss a gear (especially when shifting from 1 to 2) and it goes into neutral. Even with the clutch all the way in, when I go to shift it back to 2nd because I missed the gear, I get a very LOUD clunk. This will happen if you miss a gear in any other gear as well. Its extremely difficult to reproduce, but I have noticed that I don't have that problem when I wear my riding boots.
Just some food for thought.
Old Mar 31, 2008 | 10:18 PM
Martin_D's Avatar
Hasnt happend since, thank God.
And I wasnt wearing "riding boots" but I was wearing combat boots. Dont know if that makes a difference or not. (steal toes)
AirmanSkee
Sep 3, 2013 09:59 PM
nodaker
May 19, 2009 01:00 PM
99 CBR F4 Man
Jun 7, 2007 01:34 AM
99 CBR F4 Man
Jun 4, 2007 11:38 PM
insanearmer
Mar 6, 2006 11:17 AM
