Another "my bike won't start" thread. Sorry :/
What's the harm?
EDIT: So lets say I push start it and it fires up, indication that it's battery related or could their still be an underlining problem?
What sort of bad things? I gotta be honest, I've done it at least twice or so and everything seemed fine. I was under the impression that it was ok...
What's the harm?
What's the harm?
If you push start it and it fires right up and will stay running with no problem then 99.99% positive it is your battary. If it will not stay running then you have a stator or Rectifier/Regulator problem.
If you jump start it from a car leave the car's engine off, do NOT start it. A car's charging system puts out a lot more amps than what the bike's electronics can handle.
Yeah, I've defiantly done it with the car running. If it would fry anything what would it be?
The huge car battery has more than enough 'juice' to start a bike when the car engine is off.
I'm going to get the battery checked to see if it's damaged (e.g. cells and can/cannot hold charge).
I'm going to check the continuity of the side stand to see if that's in proper working order.
If say the Stator or Rectifier/Regulator is done how is that replaced? Is it a single unit? Part of the starter?
If there is anything else I should look for please let me know.
Thanks for the help thus far. I really wanna ride :/
Yeah, that's the first thing I intend on doing. I will let you guys know how that works out. Going to take me a few days before I can though.
starting problem
im having the same problem on my 96 cbr 900rr. replaced the battery, it does the cranking noise but doesnt turn on. im thinking its the spark plug issue but not sure. could be the battery. i bought a new one today, acid battery. the salesman said "just fill her with acid, leave her open for 20 mins and then put her on the bike, should start up" i said that i always charge my batteries for 4 hours before installing to which he said "this one is already charged you dont need to charge if you are going to put it on the bike and use it right away." so i followed his idiotic advice, took it home, did not charge it, and didnt work. oh and i blew a fuse! charged it after, still no use. took it in to the store, they metered it in at 13. should work they said. so i returned home, put it back in, no go. new fuse too. it clicks as if wanting to start but nothing.
