almost 500 miles
so i currently have about 420miles on my 06 600rr, i know that i need to take her in for a 500 mi check up, but what other maintenance does my bike need, keep in mind that i have done nothing up to this point other thatn break her in as gentle as possible, and keep her full of gas. my i just want to know that i am doing all i can to keep er happy and healthy. oil? chain lube? wisper sweet nothings?
thanks for the info as always |
RE: almost 500 miles
When you take her in for the check up the dealership will whisper all the sweet nothings for ya... ;)
ORIGINAL: pruchnicki44 . oil? chain lube? wisper sweet nothings? thanks for the info as always |
ORIGINAL: Fretless33 When you take her in for the check up the dealership will whisper all the sweet nothings for ya... ;) My dealer charges an extra $100 for sweet nothings. |
ORIGINAL: kiggy74 My dealer charges an extra $100 for sweet nothings. |
If they're a good dealerthen the service dept. will keep a record that the bike was at least brought back once for service. THEY ARE SUPPOSE to go over the whole bike make sure everything is still tight, adjust/lube the chain, check clutch/throttle cable specs, check psi, and change the oil. Glorified oil change in the house! But at least that it's on file that a service was done at the recommended interval. After that if you want to do it yourself keep all reciepts for filter, oil and other lubes.
Congrats and be safe. |
