2009 CBR600RR has no power
Whoops, my mistake. I didn't realize they changed it up so much on that generation of 600rr. On the generation 600rr I had, it was directly behind the battery, but demon has pointed to it correctly.
Edit - this was what I was talking about. Sorry for the confusion
Do you have a manual for the bike? The exact location may even be in the owners manual.
You really need to find the hidden fuses and check them. Don't assume they are good.
How did you check the fuses in the fuse box? I bet they are good, but have no power to them...
The fuse that is on the starter relay is new and so is the starter relay. Checked the fuses with meter. So the fuses in the fuse box behind battery and the starter relay that is to the side of the battery with the fuse has all been checked with a meter and check out good. But there is still no power to the bike.
Is there another hidden fuse somewhere I can check? What about the ignition relay? Could that have blown out? And there is also the possibility that the ECU could have blown as well.
No manual for the bike.
