2003 honda cbr 600rr need some help again lol
Old May 26, 2016 | 02:20 PM
Mr Bling's Avatar
Default 2003 honda cbr 600rr need some help again lol
My radiator broke so I just got it fixed and putting it back I noticed it won't start the headlight won't work the signal lights won't work and the rear signal lights stay on all the time...there is a fuse under the passenger seat when I remove it and put it back in it will start but the next time it won't any Idea's
Old May 28, 2016 | 04:13 AM
Sam Scaife's Avatar
Check your front wire harness for bad wires. Even a little burn on the outer casing should be dealt with. Also make sure all connectors are firmly together with their correct plug. (Usually easy to tell) if any fuses pop it's usually a short or a possible incomplete circut. (Pull a tail light bulb and turn on the ignition. It will blow the fuse for the rear because the incomplete circut will not have the resistance from the second bulb.this is the same with the front as well. Hope I helped. I figured this out the hard way.
Old Jun 2, 2016 | 10:58 AM
Ditch's Avatar
How did the radiator break?
Mr Bling
May 1, 2016 02:44 PM
EViR
Jan 16, 2013 06:36 AM
kentuckydiesel
Feb 19, 2008 06:37 PM
clean929
Jun 15, 2007 01:58 AM
infamous01
Jan 25, 2006 12:40 AM
